Error while running Adjust Exchange Rate Batch
Hello,
My Client received an error message during Adjust Exchange Rate batch job run.
Posting Date is not within your range of allowed posting dates in Gen. Journal Line Journal Template Name=’’,Journal Batch Name=’’,Line No.='0’
The error is received for a particular user only, for others it is ok.
Please suggest a solution
Check the “User Setup” table. Here it is possible to set individual Allow Posting From and To dates for the users.
Hi Erik,
Already checked the User Setup table. Actualy process is run for August month.
The User Setup Table has range of dates from 1/8/13 to 31/8/13.
Ok and is that the same period you’re running your adjust exchange rate job for as well the posting date?
Yes. Adjust Exchange Rate Batch Job is run for the month of August, i.e. 1/8/13 to 31/8/13.
Check GL setup also for the same…
