Error while reversing the GRN
I am getting the error ‘Inventory is closed for physical and financial transactions untill 3/31/2014’ while trying to reverse GRN. The inventory for the period has been already closed and i do not want to reopen again.
Can i reverse the GRN in the current fiscal? if yes what will be the effects in the system?
Expecting correct solution for this issue at the earliest basis.
Thanks in advance.
– Vijay
When you reverse the GRN, system doesn’t give option of date. It simple cancels the transactions.
I will suggest you to cancel the closing , do the required transactions and process the closing again.
Pranav…
