I have created a purchase Order, taken with the negative qty of 2. Completed the receiving of all 2. Now while posting the
Purchase Invoice, AX is giving below error.
"AX 2012<< insufficient inventory transactions with status sold. Compare purchase order and invoice values. Update
has been cancelled."
When I check the Inventory transactions for the respective Item for that PO. It is showing two lines, one with status deducted as 2
and other line with status on order quantity 2.
Please suggest some solution. If faced such kind of issue. As far as I know. If I receive all the quantity on Purchase order It should not show anything on InventTrans table as On Order or Ordered.
Note- I am using three way matching. But after removing three- way matching also getting this error.
