error while posting purchase return order
I am getting following error while posting purchase return order
Quantity (Base) must be greater than 5 in Bin Content Location Code=‘UTL STR’,Bin Code=‘UT-DEFAULT’,Item No.=‘24100220041’,Variant Code=’’,Unit of Measure Code=‘NOS’.
is there any thing i am missing
I guess the quantity in bin content is not sufficient to return the order…
did you use the Quantity in bin content at some other place?
How you are doing Purchase return order ?? Is it by using copy document functionality against particular posted receipt ???
Are you using Warehouse Management System? Or only BIN funtionality?
If WMS, then you need to create a new Whse. Shipment to create a Pick and Register it.
