I am getting error when i try to Create New Vendor or edit the Vendor in AX 2012 R3.
I have attached the Screenshot with this post.
Also find below the error:
Stack trace: Field ‘DunsNumberRecId’ in table ‘DirOrganizationBase’ has not been explicitly selected.
Stack trace
(S)\Data Dictionary\Tables\DirOrganizationBase\Methods\editDunsNumber - line 7
(C)\Classes\QueryRun\next
(C)\Classes\FormDataSource\executeQuery
(C)\Classes\FormDataSource\linkActive
(C)\Forms\VendTable\Data Sources\VendTable\Methods\linkActive
(C)\Classes\FormRun\run
(C)\Forms\VendTable\Methods\run
(C)\Classes\FormFunctionButtonControl\Clicked
Kindly do check on this issue/error and update me the solution at the earliest.
Thanks and regards,
D Praveen Kumar.
