I have install the NAV 2013 in server its working with cronous database, now remove and delete the cronous database and restore the other database , now its thorough an error that server is missing, where as I have change the database name in customconfig file also. still the error.
Did you get an answer to your question? Did it help you? The members and moderators here on DUG use our spare time and help you for free, all we ask in return is that you spent a few seconds to let us know if we helped you solve your problem.
If any of the suggestions helped you solve your question/problem, then please click the “Verify Solution” on the answer that helped you, so that we can see that your problem is now “resolved”. Otherwise let us know how if there is something else you like to know.
