I keep getting this error when posting a retail statement. “0.25 cannot be picked because only 0.00 is/are available from the inventory.”.
the message means that there is no quantity for that item. and so I created a movement journal on the statement date and added this quantity to the site and warehouse specified. however the error remains. i also tried to clear the statement yet it gave the same error. how to solve this issue?.
This is a very typical error in AX. It is saying there is not enough unreserved inventory available. Check to see what is specifically available in that location.
Hi Hassan, is the issue unit of measure the same than the inventory unit of measure? If not, check the conversion factor and the number of decimals between the different unit of measure.
What dimensions does your transaction has? Check if you have the inventory onhand for those dimensions. You should be having the inventory with the relevant dimensions, if the Physical inventory is enabled for that dimension.
