I have SQL SERVER 2008 installed on WIN2008 Server including analysis services and reporting services.
I installed AX with analysis and reporting extentions. I can access the reporting site at http://localhost/reports and http://localhost/ReportServer and also connect to the report service using the management studio
When I deploy reports (e.g. cust), I get an error:
Deploying 1 data source(s) and 8 design(s) in 43 culture(s) (345 item(s) total)…
Unable to connect to http://ax2009ins/ReportServer/ReportService2005.asmx as specified in the config file for the report server at c:\Program Files\Microsoft SQL Server\MSRS10.MSSQLSERVER\Reporting Services\ReportServer\RSReportServer.config. If this url is not correct please update the config file, otherwise make sure the report server is configured correctly.
I disabled the proxy connection to the internet for all the accounts on the server and also increased the value of SQLCommandtimeoutseconds parameter in rsreportserver.config to 300, but no use.
I hope you will be able to assist me in solving this issue.
Here is the full error from the log file. Maybe it will help:
Error: Unable to connect to http://ax2009ins/ReportServer/ReportService2005.asmx as specified in the config file for the report server at c:\Program Files\Microsoft SQL Server\MSRS10.MSSQLSERVER\Reporting Services\ReportServer\RSReportServer.config. If this url is not correct please update the config file, otherwise make sure the report server is configured correctly.
Deployment failed with the following exception:
System.Net.WebException: The operation has timed out
Deploying a report will be made in every installed language…
try deploying only one report library and use the report-deployment from the startmenu (not from inside the ax client) and start it with rightclick - runas administrator
