Hi Guys, hope you can help me on this issue. I am trying to perform SQL synchronization in AX client but this error log appears. I don’t have any idea how to resolve this.
Thanks in advance .
Thanks in advance .
hi,
Do you try to locate the log file and remove it?
regards,
WT
Hi WT. I already tried but the error still exist
Could be the permission issue. Make sure that you have full write permissions to the path.
Once try restarting the server and check as registry errors sometimes do also cause this kind of problems.
Agree with Kiran.
Please use the AX userID to find and delete the file.
if cannot, please check the AD access right.
Do I need to delete the whole log file or just erase the content of the log file?
