I’m getting an error everytime I run this Analysis Report under - Sales & Marketing - Analysis & Reporting - Analysis Reports. I am Exporting to Excel under Functions.
I’m picking Profit under the General Tab - All-Items - for the Date filter I have 01/01/09…12/31/09.
This is the error message I’m getting.
The sum of the values in the Sales Amount (Actual) field cannot be calculated because the filter contains question marks (?), asterisks (*), or “at” signs (@).
To me it look like its on the item analysis view entry table. To rebuild the view entry - change one of the dimension code on the Item Analysis View Card. You should be prompted to delete the entries and select yes. Then change back the dimension code and hit the update button.
Yep rebuild the analysis view from scratch. After that it would be a case of trying to de-bug it, because these first two steps deal with what teh end user controls.
This is the standard way but you can delete the entries and update the last entry No. to Zero and then update. It would be interesting to find out if the entry re-appears when the view is re-built and investigate if there is a problem elsewhere.
If you feel that one of the replies answered your question, then please click on the verify solution button next to the post. This way we know that the thread is closed and it’s your way to credit the person who helped you.
