Entry Type must not be changed when a quantity is reserved in Item Journal Line Journal Template Name=‘PROD.ORDER’,Journal Batch Name=‘username’,Line No.=‘240000’.
only one user occurs this error message while enter in to production journal. while other user have no problem when they enter in to production journal.
Did you tried debugging and see which line of code is invoking this?
Hi did you managed to solve this issue? I am having the exact same mistake.
Hi @Juan_Alberto_Hilario
I can help you with this if you need any solution for it.
Email here
Hi Sunny100, did you manage to solve this please i need help with the same topic.
Thank you
