Error Object reference not set to an instance of an object.
Ereor ID SRSReportView id 0: Object reference not set to an instance of an object.
When you duplicate an SSRS report in Visual Studio, and you try to open the design node you may get this error.
The reason is data set parameters contain the name of the report and you may have duplicated the report to other name and the report is broken.
Navigate to each data set parameter and change the name of the report to match the new name.
Raghav.
I received this error when I tried to run a report in AX 2009/ General Ledger/ Reports/ Sales Report and this happens to other users except the administrator account and the account in wich this raport was modified. I do not know what could cause this error.
Your answer will be highly appreciated.
And although the change was made to the test environment , the problem appears also in the live environment
