Error::No print management settings are applicable so no document is produced.
I have Ax 2009 Account Payable Purchase order error:(No print management settings are applicable so no document is produced. ).This error pls help me.
thanks
samy.
Navigate to AP > Setup> Form > FormSetup and try to give printManagement settings there.
which setting i can modified in print management setting.
thanks,
samy
Hi Karuppasamy,
Please check this URL http://idynamicserp.blogspot.in/2012/05/ax-2012-no-print-management-settings.html#!/2012/05/ax-2012-no-print-management-settings.html
Please also read this article http://technet.microsoft.com/en-us/library/hh209383.aspx
Please make sure you have the settings for purchase order.
Hari
Hi Karuppasamy,
As Hari said do that first and then check your SSRS reporting services whether it is installed and configured.
Regards
Krisheed
