Our client uses NAV 4.0 SP2 with SQL2005 and use database authentification. When user trying to Login, after password input, user receive message: Error: [Microsoft][ODBC SQL Server Driver]Operation invalid at this time State ID: HY011 How to solve this problem?
Did you install the hotfix for SQL2005 of Navision 4.0SP2?
I need this hotfix, please help me. adamut@gmail.com
If you are a partner you should request it in partnersource. If you are a customer you should it to your current partner.
