Hi Guys,
Good day!
When I create a free text invoice transaction, I got this error message. Someone knows how to fix this? Please refer below screenshot for you reference.
Looking forward to hearing from you very soon guys.
AML
You can change the property AllowCheck to “No” in the data source CustInvoiceLineInterProj in CustFreeInvoice form.
Also check the security matrix for the privileged access.
Jaleel
Thanks for the reply. appreciate it! but how can I do that? can you please provide a procedure or screenshots?
Looking forward to hearing from you very soon.
Thanks!
AML
How can I do that? can you please give more details?
Thanks!
AML
Does it happens with all users including the admin?
Do you have license for project1?
Do the time sheet configuration key is been enabled?
Hi Kranthi,
I am actually using the admin for login.
What do you mean for license for project1?
How to check if the configuration key has been enabled? can you please give some screenshots?
Arnel
In System Administration → Setup → Licensing → License information → Feature sets tab , see if there is a code for Project I
If you have this code, in License configuration → under Project I, see if the the time sheet config key is enabled.
I tried by disabling the time sheet config key and got the same error. The free text invoice should work irrespective of this key.
This is seems to be a Bug. The obvious fix is to set the Allow check property to No(as said by Kristine).
