Error Issue: Cannot Correct Negative Quantity in Adjustment Bin for Directed Put-away & Pick Location
Hi everyone,
I’m stuck in a loop trying to correct a negative quantity in an adjustment bin inside a Directed Put-away and Pick location, and Business Central is blocking every known correction path. (I’m doing this on my own time just working in the system and getting my hands dirty etc. Its a demo account but want to learn this nonetheless)
So heres some of the background:
The Location
Location = WHITE-WMS
Directed Put-away and Pick = Yes
Adjustment Bin Code = A-01-0001
Item = 1900-S
Current Quantity in Adjustment Bin: –20
The Issue
At some point a negative adjustment landed in the Adjustment Bin (I thought I was doing a positive on but must’ve accidentally made it negative) leaving it at –20. Since then, all correction attempts fail because of the combination of:
Adjustment Bin Code assigned to A-01-0001
Quantity cannot = 0
This creates a situation where BC blocks every warehouse or inventory correction method.
**What I’ve done so far (they’ve all led to blocks with F5 refresh prompts):
Warehouse Item Journal**
Fails with error:
“Adjustment Bin must not be Yes in Bin Location Code=‘WHITE-WMS’, Code=‘A-01-0001’.”
Item Reclassification Journal
Fails with error:
“You cannot use a Bin Code because location WHITE-WMS is set up with Directed Put-away and Pick.”
Warehouse Movements / Internal Movements
Creation is blocked or BIN cannot be selected due to DP&P being enabled.
Warehouse Physical Inventory Journal
Even after running Calculate Inventory, selecting the Adjustment Bin triggers the same error:
“Adjustment Bin must not be Yes…”
Attempt to clear Adjustment Bin Code on Location
BC blocks this because the bin is not empty.
Attempt to disable Directed Put-away and Pick
BC blocks this due to existing configuration dependencies.
So the current issue is:
A-01-0001 is stuck as the Adjustment Bin
  1. The bin contains –20, so it can’t be unassigned
  2. No movement or journal can post into or out of it
  3. DP&P prevents all alternative bin-level corrections
  4. The system effectively traps the bin in an unfixable state
Is there a way to resolve this? Thank you
A negative quantity in an adjustment bin under Directed Put-away and Pick can get stuck because BC blocks all normal corrections. A simple workaround you can try:
  • Create a temporary location without Directed Put-away and Pick.
  • Use an item journal to move the item out of the adjustment bin into the temporary location.
  • This helps you bring the adjustment bin back to zero without triggering DP&P checks.
  • Once the quantity is zero, remove and reassign the adjustment bin in the location setup if needed.
  • Then move the inventory back to the main location and continue as usual.
If it still doesn’t clear or behaves differently in your setup, we can always jump on a quick knowledge-sharing call and walk through it together.
Hi Hardik,
For sure I’ll give it a try tonight and keep you posted. Thank you.
I noticed that direct messaging isn’t available here. How can we share our contact information privately?
You can directly reach out to me at hardik.gupta@allgrowtech.com
