You created your tax group “test” did you then tell the system the rate and posting to undertake when it is transacted with the item tax groups? Sounds to me like you did not, so set the tax up correctly!
Yes I did set the rate up… not sure abt the posting to undertake… Actually the recIds are not being retrieved in the class “Tax”, in the method: “InsertIntersection”… which is the reason y I’m no able to retrieve the needed data
