I created a class with modifier public, Later on I removed the modifier.Prior to changing the modifier, everything was running fine. But after I changed the modifier and run the code, the instance of that class could not be created and gave the following error:
Now I am trying to duplicate the same class or create a new class with a new name, but then also same error is being thrown.
I have cleared the caches, reset the usage data and have reopened the AX env. But it has not helped.
Please help to resolve the issue.
