Error : Insufficient memory to run script
Is there anybody familiar with the error ‘Insufficient Memory to run script’.Whats the main cause of this error and the best way to deal with it.Please reply.
Regards
Vj_iway
It depends where. But hotfixes have been released for this for AOT compilations and if you post or validate a General Ledger journal that contains more that 10,000 lines in Microsoft Dynamics AX 4.0 you get this message if a company logo exists and there is a workaround.
I suggest you report it to your partner/Microsoft assuming you have no modifications in this area.
Well, thanks for your Quick response.
Moreover it is also like if this error appears once ,Then it keeps on repeating for the whole time even if we open any form ,any report ,unless the dynamics services in the AOS server gets stopped.
Then again we have to restart the services.So the Dynamics services in the AOS server, some way or other is related to this kind of error.Also what should be the ideal no of maximum open cursors in the Microsoft ax server configuration utility.
Regards
Vj_iway
While searching for something else, I bumped into this thread.
The problem is due to 10 MB memory limit set by Ax. For more info on this error and also ways to resolve it, please click here.
