Hi everyone,
I am trying to import a table in NAV 7…
I get the following error:
You cannot enter ‘Object Table 5200 Employee {OBJECT-PROPERTIES{Date=05/09/12;’ in FieldNo.
What can I do???
Hi everyone,
What can I do???
Sounds like you’re trying to import with a wrong file setting or a mix up of the text format and fob format object files. Or there might even be a syntax error in the text file.
Actually I upgraded the object from NAV 6 to NAV 7 and I tried to import it on NAV 7…I got the error…
I didn’t change anything at object properties…
you mean you have done object merging?
if yes, you have done something wrong in merging…
Poppins,
Did you solve you problem?
