Dear All,
Guide in the following scenario… i am learning NAV 2009 R2. during this period of learning
i have created a Role Center Page
Created a Sales order Processor Queue Page
Added Actions to the Sales Order Queue Page
Added Parts to the Created Role Center Page…
After adding Parts when i run the Role Center page i got the following Error:
“The Microsoft Dynamics NAV Server cannot connect the Change Listener to SQL Server because of the following error: A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: SQL Network Interfaces, error: 25: - Connection string is not valid”
When i searched in Web found solution to above error as i need to “Enabling the Object Change Listener”
So i am trying to do as per the guidelines suggested in http://msdn.microsoft.com/en-us/library/dd568739.aspx
Currently i have installed SQL Server in my laptop. my server account name is Lucky-Pc\Lucky… with Demo Database NAV (6-0).
When i am executing the instructed lines i am getting following error
"Msg 15025, Level 16, State 2, Line 2
The server principal ‘Lucky-Pc\Lucky’ already exists.
Msg 111, Level 15, State 1, Line 3
‘CREATE SCHEMA’ must be the first statement in a query batch.
Msg 15151, Level 16, State 1, Line 1
Cannot alter the user ‘Lucky-Pc\Lucky’, because it does not exist or you do not have permission.
Cannot grant, deny, or revoke permissions to sa, dbo, entity owner, information_schema, sys, or yourself "
PLEASE LET ME KNOW DO I NEED TO CREATE NEW WINDOWS ID FOR Enabling the Object Change Listener and Why it cannot be applied to existing user
Thanks in advance
Regards
Pavani
