Hi EveryOne,
I have to add new records lines in Purchase order form…its show an error like "Company :ceu Conversion of item number
Conversion of code was not specified" Am using Ax2009
how to solve this problem?Any one Help me for that problem
Hi EveryOne,
check item master, inventory unit and purchase unit must be different. If different then you need to specify conversion for the same. convert from one unit to another unit.
I hope this will help u
Thanks Suvarna[:D]
Hi saravanaa,
If you got solution in any comment, please make as solution. (now you need to do for Suvarna)
Thanks.
