error in production order calculating bom comsumption
dear all,
Does any one know what is the problem with the production order.
The problem is when i try to post released
thanks in advance
it means you have configured the system to job schedule and have not told AX which number sequence to use as a job identifier. Go to the number sequence in the error message and define it or run the number sequence wizard and define it.
