I am geting one Error when i create Excel Sheet. The error is " An Exception was raised in method range.The OLE control of automation server has returned error(HRESULT)-2147352567.The component did not provide Exception description."
Whats the problem with it…??why its coming??how to solve this?
One possible (and most common) reason could be, that as “Custom Controls” there are registered a bazillion for MS Office – in this case for your interest are those regarding Excel .
Problems CAN start appearing, if you have concurently registered the same control for several Excel versions. Solving is even more problematic, because you can’t guess which version of Excel client has (and can have different on different workstations).
This is something like Winnie the Pooh said about bees - you can never know…
Theoretically, these concurrent different version controls SHOULDN`T cause problems, but I constantly get them - for example, export works on one workstation, but on another it starts returning weird messages as one mentioned here. Only difference - some had older versions of Excel, some newer. As licensing permitted, we upgraded all WS to one common Excel version, unregistered everything we could find to be dealt with Excel of other versions in “Custom Controls”… The result - now we get error messages more rarely, but now on ALL workstations [:D]
