Dear all,
I’ve got this issue when I am trying to End Production order. The error message as screen shot below:
We are using “Standard cost” for both FG & RM.
Does anybody here have experience on this issue? Please share with me how to fix this?
Thank you in advanced.
I presume the production order unit is not the same as the inventory unit?
What is your costing setup in the costing version to do?
What is the raw material and final production active costs?
Are you using by-products or co-products?
All unit type are using the same.
I already done to update the active cost to higher than calculated cost of Produciton Order. I did as following steps:
Reset status to “Started”
Reverse RAF journal
Update Active cost to higher than Calculated cost of Production
Re-run RAF
End, but still got above error message :(.
When I checked the License Plate of RAF journal, I found that Warehouse user already release this quantity to Sales Order, and this SO is already Invoiced.
Can I reset status of this Production to Estimate now? (the quantity is already released)
If the stock is there it is taking out stock unrelated to the production order to correctly reverse RAF, which is an issue, especially if you are using WMS and it is connected to a sales order.
You would now need to start debugging it and have the code explained.
