hi
when i run the Tutorial_WorkflowProcessor form am getting this error "Error executing code:treenode object not initialized" AX 2009
hi
I think it is unable to get the outcomes related to that work flow approval.
Did you see the outcomes under Workflow → Approvals (AOT node)?
Yes kranthi i can see the outcomes under workflow -->Approvals
Is there any Other solution for this error please suggest me
you can start debugging from getOutcomes method.
Thanks for your reply. I will check from my side and will get back to you
It does mean that it is not a valid path or you don’t have the outcomes defined.
Can you post a screen shot of the outcomes?
Ok sure here is my workflow approval outcomes
What does this.path() returns?
returns the Workfflow>>Approvals>>PurchOrderApproval>>Outcomes.
It’s working fine, thank you so much for supporting me
