we use NAV 5.0 and i have another problem if i will post the receive in a Porchase Order. For sone PO´s all with the same item i get the following error:
"Dimension Value for XXXXX is missing"
but the missing xxxx is in the order and item dimensions and everything looks normal. Can someone help to find out the reason and way to fix it???
I would guess you re posting to a General Ledger Account with a Mandatory dimension, which is missing. Try to check the settings for the ledger accounts you are posting to. You can also delete the lines and resubmit those lines.
And some times users do not metion the dimensions because it was not made mandatory for Interim accounts but was made mandatory for Direct unit cost, or the accounts which are being posted at the time of invoicing. I would suggest to see this as well.
