Problem solved ( was a router problem) Edited by - Pope On Acid on 2001 Dec 04 12:14:09
PS: When problem is solved, then please close topic. Don’t delete or edit the problem description, even if you don’t have the problem anymore, because then you’re not able to help others who might have the same error.
