Error 'Cannot execute the required database operation.The operation failed.' AX2012 R3
Hello all,
While opening AX client we are getting below error
“Cannot execute the required database operation.
The operation failed. [Microsoft][SQL Server Native Client 11.0][SQL Server]sp_cursor: The cursor identifier value provided (0) is not valid.”
in the Event log we find below message
'The description for Event ID 193 from source Microsoft Dynamics AX cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
Microsoft Dynamics AX Business Connector Session 9.
Could not load assembly ‘Microsoft.Dynamics.Retail.StoreConnect.TransAutomClient, Version=0.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35, processorArchitecture=AMD64’ or one of its dependencies.
I have done syncronizing database and Re indedx. Still the issue persists.
Could you please assist?
Thanks.
we syncronized DirpartyTable which we found in error log of db syncronization . Now we are able to access AX client without any issues.
