I’ve added 3 columns in the “SalesInvoiceTmp” table after this customization in the table my sales invoice report renders no output on the screen even my temp table is getting inserted with proper records.
So I just decided to revert my changes on the table. Deleted the 3 columns from the table after this I’m getting the error(Shown below) on the Visual Studio when I tried to refresh the Dataset or while attempted to edit the data set of the report.
I’ve done the following step before refreshing the data set of the report.
Sync the data dictonary.
Generated incremental & Full CIL(Removed the files from Xppil folder).
Restore & compiled(Compile Forward) the entire class related to the report and some framework class like SysDictFieldMetadata, etc… (Just a greed to fix this issue anyhow).
4.Stopped the both servers AX, Sql Server & removed the .AUC file from the appdata for the user.
Reset the AX user data and refresh the AOT Elements.
Removed the fields in the design of the report where the 3 columns were occupied.
Now…
Same error popping up… Any help on this would greatly appreciated. Thanks.
