dkumars
November 30, 2016, 8:32am
1
I am getting issue in Navision at the tyime of filed addition in table due to this issue now complete ERP is now working
please suggest solution …i have no backup for table …
Microsoft Dynamics NAV Development Environment
The following SQL error was unexpected.
Either the parameter @objname is ambiguous or the claimed @objtype (COLUMN) is wrong.
OK
Can you explain a bit please, What you did actually?
When i add new filed on table then issue occur which was given above …nighter it is delete nor resoved the issue …now complete rtc is not working…this is navision 2013r2 project…
You need to check if the table has the same no. of fields in SQL server management studio. If not create it there manually.
OK, in that case there could be many Possibilities
Did you checked this
forum.mibuso.com/…/either-the-parameter-objname-is-ambiguous-or
