we need some urgent help from your side to resolve our issues.
after installed some 3rd party software (LS Retail), we restarted the server.
The main Ax dynamics services not started automatically and when we tried, it gives the below error. please note that, the user have full permission who is running the services and application.
“Error 1067 Process Terminated unexpectedly”
when we tried to install windows installer then also its gives another error as below
“Not enough storage to run the process”
because of the above issues, the Ax 2009 application is not running and giving below error message immediate if we open the application
“Connection with the application object server could not be established”
our OS version is windows 2008 and SQL server 2008
On the AOS service, did you try entering user credentials of service account again and start service?
Regarding the message ‘Not enough storage … process’, I have noticed that error message in previous versions of Windows. But not in Windows 2008 series. In any case please refer to this KB article - http://support.microsoft.com/kb/225782
we check this and still the service is not working, even now when we press “start” on the service its status become “starting” but its not become “started” even when we left it for 12 hours the status still “starting”.
is their other security configuration i need to chack?
