i have downloaded the VM from partnerSource. I have tried accessing Ep, unfortunately it is not UP.
Can anyone please let me know, if any setups are done to make it work?
Thank youu…
Thank youu…
I believe EP needs the VM to have an internal network interface, and the correct IP addresses assigned to this network interface.
At the place you downloaded the VM, there is a PDF called ‘Technical guide’ that covers all the required setup.
Note - to help set the IP addresses, read the PDF ‘How to use Set IP Utility’
