I have Windows 7 in my PC and want to install EP.But it requires WS 2008 i believe.Is there any workaround for it? Kindly guide me.
Gayathri
Gayathri
I was facing this problem from 4 months, After repeated efforts i finally installed the EP in my windows7 i.e. for standalone installation of AX.
I hope that you know the prerequisites of EP. For installing of these requirements you need to do the following steeps.
Before going for installation steeps, can you conform that your PC is installed with standalone installation for AX ?
Conform me this i will proceed farther.
Windows 7 OS will not allow you to install the AOS normally.are you using the client in your machine?
Its not a standalone…conformed woth a domain only…
