I have two tables, one table have data(20 rows), i need to insert continueously the out put data in to another table. but that first table remain same. it should not affect
Hope you understand the requirement. company conduct survey to employee like 20 to 25 question’(constant), that question will be same. all the employee should answer(that wil insert in another table). is this possible to achieve in EP.
I already created and display question in one axform through dataset. now my question is how to insert output in another table.
am new to EP. just past week only started to work. please reply
Already i did what you said, and display the record through grid in EP now.
My quest is in save(click event), I need to pass the grid record into data set(data method) and insert in to another table.
I know the click event calling dataset(datamethod), but now i need to know how to pass the grid(AXdatasource) value into data method and insert into another table
Thanks for your reply arun. That problem solved through calling dataset(datamethod) in button click event and passing parameters and inserted in new table.
Now issue here , I create label to design for EP web page in visual studio, In label if i write text in Arabic it dispaly arabic in .net design page but in EP it display like “???” . Not support Arabic Language.
How to display arabic language in EP also. if know pls reply ASAP
