EP AX 2012 R3 - Sharepoint 2013 support
We installed the EP for AX 2012 R3 on Share point 2013. But getting the below error on most of the pages.
Error message: “Data or Calculated fields with type ‘Void’ are not supported”.
Anybody faced this error before?
And also I want to know Sharepoint 2013 supports the installation of AX 2012 R3. Because In MSDN, We are seeing the message “Currently SharePoint 2013 is supported only with Microsoft Dynamics AX 2012 R2.”
Thanks in advance,
Arun
FYI
http://dynamicsaxlounge.com/2013/10/11/error-ssrsep-error-when-the-return-type-in-display-method-is-incorrect-dynamics-ax-2012/
https://community.dynamics.com/ax/f/33/t/103584.aspx
Already went through the links. They are dealing with different problem.
Arun
