Hi Experts,
I need Sync the all the environments like Dev, UAT and QA as same as Live Environment but there are lot of differences like field level, schema name and process etc.
And when I tried to import a solution from Live to lower environments I am facing dependency issues like never ending process. Please help me with road map to achieve Environment Sync.
Kindly help me in above issue.
Can you not just create new copies of the Live to recreate new Dev, UAT and QA Environments so that they are in sync?
Hi AdamTravers,
when we are trying to create new environment, we are getting Database space issue.
Hi, when you restore a copy of the live I would immediately bulk delete data from the core tables to reduce the space being used, this may help you if you dont already do this.
All Activity Tables
Account Table
Contact Table
Opportunity Table
Cases Table
Etc. etc.
