Take a look at the properties for each enum element, there you will find a property called “EnumValue”. Basically you can swap the enum values - put enumValue 4 for the element E3 and enumValue 3 for element E4. As you cannot assign the same number for two elements simultaneously, you will have to temporary put, let’s say, a value 99 for element E4, then set a value 4 to element E3 and then go back to element E4 and set it’s value to 3.
If you literally wanted just to swap E3 and E4, the best practice would be to create a small update job to run through all the records and change those values.
ttsbegin;
enumval = 0;
val = 0;
enumval = Source.SARGlobeTrackAmount[1];
val = enum2int(enumval); // here i am getting the value of enum
Source.SARGlobeTrackAmount[1] = val + 1; // here i want to assign existing value + 1
for update a filed in every record in the table you can use this code :
while select forupdate Table_Name
Table_Name.number_code+=1; // u muse create table and a field for example number_code or other …
Table_Name.update();
************* this is certainly working *****************
