I have created a new form. There are two groups in that . First group works as a selection criteria where I have added few fields for the selection. I mean that when user gives some value in the selection fields and click OK they get records based on the selection in the line level.
Now, the problem is in the selection criteria one of the field is of type Enum which has three values Confirmed, Picked and Packed . When I give Picked and select Ok I get the records in the line level.
After that I try to remove the criteria from the enum field , and click ok , the deleted value from the enum again populates back.
Abhishek
