Enum comparison
Ihave an Enum ItemItype with following values
0 - Item (in en-us) and Article in (fr)
i am using en-us version of Axapta
now,
i have an excel sheet from which am reading values for ItemType
the excel is in french. so the value of ItemType is “Article”
i want to compare this value with enum
am using following code
str s1 = “Article”; // = “Item”;
if(str2enum(ItemType::Item,s1) == itemType::Item)
info(“Equal”);
it works only when am in french version of axapta , since value of s1 = “Article” (fr)
how can i make this comparison language independent
Any hep is Most appreciated :slight_smile:
Thanks & Regards,
Harshini
Hi Harshini,
I’m not sure of getting list of all languages. But you can try below code, it may help in your case.
static void Enum2Label(Args _args)
DictEnum dictEnum;
int valueIndex;
LanguageId languageId=‘fr’;
int enumId=enumNum(ItemType);
str labelId;
dictEnum = new DictEnum(enumId);
if (dictEnum)
for (valueIndex = 0 ; valueIndex < dictEnum.values(); valueIndex++)
labelId = dictEnum.index2LabelId(valueIndex);
info(SysLabel::labelId2String2(labelId, languageId));
Ambanna Yatnal
