When you create an Enterprise Portal (in our case Axapta 3.0 SP3) and you want it to be available from the internet you have to make a change with SQL directly accesing the Axapta database. In the Table ‘WebsiteTable’ you have to change the value of the field ‘Url’ from the netbiosname to the full name, so it can be found through DNS on the internet. Otherwise you’re EP won’t work after you logged in. MS should make a change so it is possible to change this ‘Url’ from within Axapta and not bij SQL (it’s never recommended to make change to your database by SQL). Greetings, Jurgen van Zeeland MBS Consultant - Axapta Database MSSQL - 3.0
