I want to install Enter Prise portal , I have installed dynamics ax 2009 sp1.
in server1
Now I want to install Enter prise portal in Server1 cause this is Dynamics Ax server machine.
but In Server2 already installed Sahrepoint services .
I have rights to use that server2 Sahrepoint services Now can how to install Enterprise portal in server1?
I am trying to install EP ( means RolesCenters and Enterprise portal Dotnet business connetor) I am getting error info is connection with application object server is not established
You have to install EP and RC in the same server where you have installed SharePoint.
Regarding the error - check the configuration (such as AOS server, port number etc) of Business connector is correct. Information on BC configuration is available here - http://technet.microsoft.com/en-us/library/aa548683.aspx
