Can any one help me with elimination process while running consolidation between two companies.
Below is the scenario:
Consolidation company – CONS (currency - USD )
Subsidiary companies – Comp A (currency - CDF ) & Comp B (currency - USD)
There are some inter company transactions posted b/w Comp A & B, while running consolidation these entries needs to be eliminated.
I am confused with the std material which talks about Elimination rule, Source company & Destination company etc. Also in lines form under elimination rules form need to map ledger a/c’s in source column.
Now the question is:- If there are many ledger a/c’s then do I have to map each a/c with new line or how ?
And the elimination rules to be created in consolidation company or subsidiary company ?
When i created elimination rule in Consolidation company & mapped all those ledger a/cs which got posted with inter company entries and tried to run consolidation online process also by selecting elimination rule in elimination tab with proposal only option.
But system gives error as mentioned " The distributions do not balance" “The elimination rule … failed during processing”
Hence, please guide me with step by step configuration process for the same.
Please help…!!
Thanks to all in advance
Shrinivas
