I am trying to set up an electronic signature in AX 2012 for a table/field which is in addition to the existing standard options
In Org admin>Setup>Electronic signature>Electronic signature requirements I created a new record and the selected “Properties”
When selecting a table to reference for the signatory control it only refers to DAT entity. I am in another entity but I can’t see where/how to change this. I suspect my e-signing isn’t working as I am pointing to the wrong entity
Does anyone have any advice please?
thanks
Following more investigation, the DAT is the default and does not need to be changed
I have created successfully an e-sig for a field, eg Approved vendor against a product, without an issue. I must have been unlucky to originally select a field which could not have the e-sig setting applied
