Can any one know, how to make editable dropdown in grid ax 2012.
My requirement is if i click check box (check in) then related dropdown can be editable and if i check out that check box then particular dropdown should not be editable.
Zahir
Hi Zahir,
Its simple, Go to related DropDown properties -->: enable : no
properties : auto declration : yes
Go to checkBox → methods–> override methods–>clicked method
Write this code in clicked method
public void clicked()
super();
DropDown Name.enabled(true);
I hope it helps you, all the best
Ravindar Reddy.D
Hi Reddy,
That method is not working…!!!
Hi Zahir,
I tried before post, its working might be i understand task in wrong way if you got time pls can your more clear the task with your required fields i will try to send exact answer for that. …
I did task this way:
In form design i taken group Filtter with custAccount and salesstatus to filter the account number and sales status
I placed check box
In checkbox → override methods
I written the code which i send you.
Its working.
//Is your task is just like above or different.
Ravindar
Do auto declarartion yes for the controls
Override modified() method of ur check box
Now
Put if condition
IF(Checkboxname==Noyes::yes)
Related dropdownNAme.enabled(true);
Else
Related dropdownNAme.enabled(false);
I have a form. In that I have one check box column and one dropdown column.
In that dropdown column, I have included Custaccount , so it displays all the customer account.
If I check in a check box,then particular dropdown field alone should be enable to choose any Custaccount option(I mean Dropdown to select any of the Custaccounts listed).
Then if i check out ,then particular dropdown field alone should be un editable.
Hi Zahir ,
// Try This in checkbox clicked method
super();
if(EditCheckBox.value() == NoYes::Yes)
DropDownName.enabled(true);
else
DropDownName.enabled(false);
Ravindar
Hi Zahir,
super();
if(CheckBoxName.value() == NoYes::Yes)
dropDownName.enabled(true);
else
dropDownName.enabled(false);
Hi reddy,
Exact Solution is below.!!!
1.Method should return under Dropfield in grid
public void gotFocus()
element.clickElement(CustAccount); // Have to specify table name here
super();
2.Method should return under Form level
public void clickElement(CustAccount _custAccount)
if(conFind(selectedcustomer, _custAccount.RecId)) // Here selectedcustomer is a container which sould be declared under form class declaration
CustAccount_ds.object(fieldName2id(tableName2id(“CustAccount”),(“CustomerAccount”))).allowEdit(true); // Here CustomerAccount is Field name in CustAccount table
else
CustAccount_ds.object(fieldName2id(tableName2id(“CustAccount”),(“CustomerAccount”))).allowedit(false);
3.Method should return under form datasource level
public edit NoYes matchRecord(boolean _set, CustAccount _custAccount, NoYes _inclue)
NoYes selected;
Counter locationToDelete;
if(conFind(selectedCustomer, _custAccount.RecId))
selected = NoYes::Yes;
if(_set)
if(_inclue)
if(selected != NoYes::Yes)
selectedCustomer += _custAccount.RecId;
CustAccount_ds.object(fieldName2id(tableName2id(“CustAccount”),“CustomerAccount”)).allowEdit(true);
else
locationToDelete = conFind(selectedCustomer, _custAccount.RecId);
selectedCustomer = conDel(selectedCustomer , locationToDelete, 1);
selected = NoYes::No;
CustAccount_ds.object(fieldName2id(tableName2id(“CustAccount”),“CustomerAccount”)).allowEdit(false);
return selected;
Zahir
