Hello:) I just wonder if it is possible to use the property Border in a Report. Tried to set it to yes, but it doesn’t show on the print. Why is that? Must I set another property as well? Border color, style and width is set… If it is not possible to use, does anyone have a suggestion about how to accomplish this by code? TIA
Are there such border properties for a report? I know object like text box does have, but no such property for a report. I believe you can create borders by creating shape objects with ShapeStyle property set to HorzLine and VertLine. By creating vertical lines on the left & right margins of every section and horizontal lines on the uppermost & lowermost sections, you make your border. Regards, Hadi Lai
Hello Hadi Thank you for your answer:) On the report section there is a property called border, but it doesn’t work as I want it to. Anyways, I used the shape to make the frames I wanted. This works but it takes a lot of time to adjust them… Regards,
