Can u solve my one more problem…I have MS Dynamics Ax2009 installed with base and Visual Studio 2010 and MS SQL Server 2005 installed. I want to integrate Ax with .Net , how should i get dynamics template in visual studio 2010. please help me out.
can’t possible write here your task
I will configure all components in your system contact sekharg1980@gmail.com
This was already discussed here. Dynamics AX 2009 will only support Visual Studio 2008 and not Visual Studio 2010. Therefore it is not possible to use Visual Studio 2010 with DAX 2009.
Sir can u give me that link. I am trying to get visual studio 2008 setup asap
I guess you are referring to web project template. See whether this helps - http://blogs.bojensen.eu/?tag=visual-studio-2
Also Mey have written about project templates in his blog. Please have a look there - http://blogs.msdn.com/b/solutions/
Sir
I don’t have Dynamics template for visual studio. There on the blog u mentioned above, they are telling to copy and paste the template in Visual studio documents folder.
I just want that zip file of Dynamics template
If you haven’t already done so, please install EP dev tools. This installation will create the templates. For more info - http://blogs.msdn.com/b/solutions/archive/2008/08/09/ep-visual-studio-add-in.aspx
