What sort of CRM can integrate with Dynamics NAV? I know you can use Dynamics CRM with the connector tool, but because of environmental limitations (we don’t have active directory), we’re searching for another solution. Anyone know of other CRMs that can be inegrated?
You can do plugin for both side without using connector. What kind of ur crm (workgroup)?
Hi Alex,
Salesforce is also a very common CRM solution and an integration/connector between NAV and Salesforce does also exist.
