Dynamics AX Retail
I have entered all the information as per the manual.
I have tested the connection and the all respond as correct. I have a server with HQ and anothe for a store / till.
The data is not transfered to the store PC. The Database connection from the HQ PC returns a correct connection on test to the Retail database on the store PC as well.
Peter
Hi Peter,I have same problem.all data transferred to the store except staff and terminals.two jobs N-1060 and N-1090 is failling.Do have any suggetion for this.How u have solved your issue?
Thanks in advance.
Hi
Usually if a packet is not generated is because certain data is not populated. Thus the entire job fails. Look at the job to see what information is required/pre-requisite for the data to go through.
What happened to me was I thought they were not going down, but they were.
I had the wrong setting on the teller to get the correct layout
Peter
cau u tell me wht wrong setting u have done in POS,may be i can check wid my POS also.i am struglling wid this data replcation issue for last 2/3 days.May be some small issue wch i am not able to find out.
Are you sure that your stores are set up on the default include list on HQ? That’s a common thing when everything works fine but data is not transfered.
