md_jed
November 7, 2012, 10:53am
1
Can any one explain Dynamics AX on hand quantity and Inventory value report for stock valuation.
I tried default report from AX below path, but valuation is giving incorrect.
Reports >> Inventory Management >> Status >> Physical Inventory >> Physical Inventory by item group or Physical Inventory by Dimension
Is any one who can help and explain.
Mohammed
kranthi
November 7, 2012, 11:40am
2
The end result should be same for both the report(Physical Inventory by Dimension will give you a break up on dimensions)
look into > > > > which is mainly used for reconciliation
md_jed
November 7, 2012, 11:58am
3
Hi Karthik,
Thanks for very prompt response. I run that report mentioned above but its giving over all quantity not matching with onhand inventory quantity and value.
This report will give you the financially updated qty and the respective values.
